I'm not sure I would ever trust a hot water heater. Municipal water pressure is usually in the 65 psi to 95 psi range. When we built our current house we were only the second or third in the subdivision. We were considering having an irrigation system installed so we called a couple vendors to get estimates. They came out and tested the water pressure (we are directly down hill of the water tower), and found it to be 125 psi. They all cautioned they would need to install a pressure regulator and also mentioned the high pressure would shorten the life of the water heater.
We didn't give it much thought, and decided not to go with the irrigation system due to the cost. Things went on as normal for a few years. When we came home from a vacation about 5 years later we found we didn't have any hot water. I went down to the basement to find the tank had a 12" crack about 2/3 the way up on the tank. Fortunately the escaping water had drowned out the burner, and shut off the gas.
The next water heater we installed included a pressure regulator at the inlet. That one lasted over 20 years. We're now on the third water heater, but since the subdivision is now complete the regulator is no longer necessary. Water pressure hovers in the 80 psi to 90 psi range depending on water use.
I like the idea of pressure testing. I have 2 pressure washers. The smaller one is capable of 2,200 psi, and the larger is capable of 3,200 psi. The smallest one I've seen is capable of 1,200 psi. The big difference is in the GPM output. The smaller ones are usually around 1 GPM to 1.3 GPM while the largest commercial ones I've seen can put out over 10 GPM. Depending on output it could take 8 minutes, or 80 minutes to fill the tank.
