I do not think the lower cost Curtis compressor is made in the US.
I have had a few 2-stage compressors, it is a matter of how much air, features and price. I figure whatever compressor one buys, I would expect it to probably out live me. Better compressors usually can go 20,000+ hours and are easily serviceable/rebuildable if needed. More important factors are how quiet it is and accessories. I would stick with a 5-7.5 Hp low speed motor (1750 RPM) and low speed pump (500-700 RPM range) highly recommend an after cooler, automatic drain, and magnetic starter. I prefer US made pumps, simple because the pumps will last longer and they tend to be heavier and quieter. Almost all the mainstream compressor brands the lower end have high speed motors/pumps which cause more noise, heat and often have reliability problems. Granted, if you only use it infrequently, just about any compressor will last you many years.
I had a Curtis CA-5 previously in a compact horizontal 60 gallon tank for many years, it was easier to move and less of an issue with toppling over in earthquake territory. No complaints, other than being a bit loud, the CA-5 pump has been around for decades, all cast iron made in the US. Sold it when I moved to Hawaii. Curtis also make a MasterLine pressurized lubed compressor, they are bullet proof, similar to some of the older Quincy compressors.
Currently I have the Champion HR5-8 advantage version, the vertical model would be the VR5-8, they use mag. starters and are available in single phase 5 or 7.5HP. The Advantage (or deluxe) package includes after cooler, automatic drain, low oil pressure switch, isolation pads, etc. They are "assembled" in the US, but often parts are sourced from all over so who knows. This is considered their industrial model series, it is also available in a pressure lube series. They have one piece cylinders and head with a steel liner, so no head gasket, comes with an inter-stage cooler and after cooler, which dramatically reduces the air temperature going into the tank so the water drops out. Mine has an automatic drain valve that works mechanically, but they also have electric ones that cycle at preset intervals. The Champion is a bit quieter than the Curtis, both are very good and will last a lifetime. When I purchased my HR5-8 it specified Baldor motor's but they switched to Marathon, supposedly at the time Baldor was having reliability issues with motor's made in Mexico. I run my compressor on a 50A circuit, probably could get buy with a 40A.
The newer IR compressor (not the industrial ones) seemed to have more negative comments these days, also the lower end Quincy models, but there higher end compressors tend to get much better reviews. They were also more expensive then the Curtis or Champion US made compressors with similar accessories, and Quincy also required you to purchase their service/oil change backs at additional cost to get the full warranty. Another brand that is also considered very good is the Saylor-Beall VT-735-80 compressors, also made in the USA, but like the Quincy they are around $500+ more than the Champion R5-8 series.
Curtis CA Series: CA5 5-HP 80-Gallon UltraPack Two-Stage Air Compressor
Buy FS-Curtis FCA05E57V8U-A2L1XX Direct. Free Shipping. Check the FS- Curtis CA5+ 5-HP 80-Gallon UltraPack Two-Stage Air Compressor (230V 1-Phase) ratings before checking out.
www.aircompressorsdirect.com
Curtis ML Series: ML5 5-HP 80-Gallon Pressure Lubricated Two-Stage Masterline Air Compressor (230V 1-Phase)
Buy FS-Curtis FML05D96V8S-A2L1XX Direct. Free Shipping. Check the FS-Curtis ML5 5-HP 80-Gallon Pressure Lubricated Two-Stage Masterline Air Compressor (230V 1-Phase) ratings before checking out.
Champion Advantage VR5-8, 5HP, Two-Stage 80-Gallon Vertical Air Compressor Unit With Aftercooler
10/31/22 In stock in Oklahoma City. Champion R-Series Compressor pumps have a time-tested, proven design. Rugged standard features, a wide selection of configurations, and quality available options make the R-Series compressors the solution to your application. Delivering high performance...
www.aircompressorcfm.com
Saylor-Beall VT-735-80, note things like mag starters, after-coolers, tank drains are all extra.
5 HP, 17.3 CFM, 80 Gallon Tank, 1-Phase, Splash Lubrication - A pressure lubricated air compressor pump uses an oil pump to force lubricating oil to all of the friction points.
westechequipment.com
As far as dry air, you can get a refrigerated air dryer at considerable expense if you need absolutely dry air, followed by a particle filer and coalescing filter. I just use a Norgren dual air filter system and regulator, and between the compressor after-cooler and dual filters I have never had any water in my shop compressor line drains. I picked up the filter's on eBay, you do need to know the specific model numbers, and also the pressure ratings. These have steel bowels with a site gauge, automatic water drains and indicators if the filters are clogged. Surprisingly, I only get a few drops of water in the first particle filter.
