There's a lot of down hole oilfield equipment out there that uses a 4 pitch modified square threads and other various thread pitches, including Metric, and it's not trapezoid either. And they are mostly left hand. That allows you to "get off" of the tool by right hand torque. The leading flank is at 0 degree and trailing flank 5 degrees. Sometimes we would make the trailing flank up to 45 degrees.
Edit: Got that backwards, the trailing flank was nearly always 0 degrees or 90 deg to the thread axis. And the leading edges of the thread were at an angle from 5 degrees to 45 degrees.
Ken
