- Dec 24, 2020
- 1,048
Gene,It's entirely, **ENTIRELY** dependent on the person doing the work. Trust me. (No, really...) I have squandered thousands over the years buying crap that other people said was indispensible - that I ended up just never using. It's all down to what you do, and how you do it. The most amortized tools in my shop are: MIG welder, bench vise, belt grinder, and horizontal band saw - but if you work on a different type of project, none of those might be that important to you. OK, I don't think you can go wrong with a good horizontal bandsaw...
A quick example: a friend talked me into buying a Haimer Taster. It's a lovely bit of kit, but I very, very, rarely use it. Given its ~$500 price (at the time, probably more now) I'd have been better off buying something else...
Work on your stuff, and buy what **you** need. Listen to your friends when they tell you that you need an expensive tool, but then consider whether it will be of use to *you*.
Ignore anyone that professes to know exactly what you need...
The best thing you can do is start working on projects, and buy what you need as the need arises.
GsT
I think maybe you missed the point of the thread somewhat. It's not a shopping list, it's just what you found to be more or less useful than you expected.
Your comment about the bandsaw is actually perfect. I have a beautiful Wellsaw 613, which is a very nice saw...$8K or so new I think and I spent months looking for one. I don't use it nearly as much as I expected, and I do the vast majority of metal cutting with an Evolution S380CPS. I would have been better off pushing the bandsaw down the list a ways now that I look back.
I'm working on all kinds of projects and already have a lot of machinery for a hobbyist....two mills, four lathes, 20" drill press, shop press, arbor press, surface grinder, bandsaw, dry cut saw, super spacer, rotary table, tool post grinder, two MIG welders, two TIG welders, engine drive stick welder, 80G compressor, oxygen-acetylene torch set, two propane forges, 50LB power hammer, bench vises up to 175lbs, post vises up to 150lbs, anvils up to 330lbs, etc, etc....I'm probably forgetting stuff, but my wife might see this!
