Fair point but precision ground stones are unavailable in the UK. What do you suggest?
In the long term, ground stones are ground on a regular surface grinder. You might stumble on somebody. I'm 82 percent sure that MOST of the cost of ground stones in not the stones or the grinding, but rather the cleanup.......
Having used them, and having ground stones together, I'll second this, and second the recommendation to Robin Renzetti's video. Even if the three stone method got a stone flat, (there's caviats), it doesn't produce the end result. It just creates a flat stone. Which is better than out of the box for sure, but it's not the same thing.
Short of that, if you've got an old file (or get a cheap crappy one), the "Dead File" that Homebrewed described to me is very, very good. It's the same idea. You take the file teeth "flat" on the top, so they can not "dig in" until they hit a raised spot. A "presumably kinda flat but who knows" plate is more than adequate to stick sandpaper on. Glass, a piece of cold drawn metal, preferably not a surface plate until it's proved that it's a condition to warrant this, but really, anything that "seems" flat, and passes a ruler test will make a good dead file. It's cheap, and it's good for "bulk removal" before one would even consider the stones anyhow.
If you happen to stumble on such a thing, (it's a long shot), but "Gauge Block Stones" are exactly this. Smaller in size, but ground so that they can't take material that you didn't want to. Again, it's a long shot, but I know you guys use gauge blocks over there, so "maybe".....
