- May 3, 2020
- 359
No need to go crazy with the temperature talk. You can measure 10ths reliably in most circumstances.This.
Without a climate controlled room (no, your air conditioned spare room or basement does not cut it) and expert level practices much of this is academic.
Scrape it to within whatever measurement you like and you will distort it while taking your reading or doing your setup by resting your wrist on the edge.
This is why granite is a thing, but even then your body heat is affecting every tool you touch.
The above mentioned dished surface plate we use at work is in an uncontrolled room right under a HVAC vent and we somehow get by.
Granite is "a thing" because it is durable and brittle. It does not form burrs. In the war, they sometimes used glass. Glass is about as hard as steel, so they didn't last very well.
I don't think I could live with 0.002 systematic error. I had a cheap grade B plate and it was hard to get reliable readings for even basic stuff, like scraping a part flat and parallel within a tenth. So I picked up a much bigger grade A plate. Obviously this is not a reasonable solution for everyone but a reliable flat surface Is a great asset in the shop
You can investigate the status of the plate with a 4-footed gage, a level, an indicator set up for "repeat" readings
Surface grinding would be a good solution but you'll need to scrape some texture into it if you want to use it as a surface plate.
