I'd have it on three points.. I would personally put tiny (oiled) soft wood shims on one of the short sides, at or near the corners of that stand, and let it sit on those. Just thin ones. If you've got an old wooden yardstick that needs to be gotten rid of, that's the "scale" of shim I'm thinking. They're pre marked so you can cut off just what you need and paint stores sell 'em cheap.
And on the other short side, a single shim in the middle. Maybe a little longer to spread the weight over the unsupported angle. Maybe even six or eight inches. Wide enough to keep it from rocking (if that's an issue), but short enough to concentrate some weight so it'll "bed into" the shim, and find it's own happy place, without being influenced tangibly by the stand.
