- Nov 16, 2012
- 5,596
I have the same trouble with the vise... Keep getting my fingers pinched.
Ray
Well, the shafts are done with no immolation of self or property... I wanted to take pictures or videos but seriously, cutting with ceramic is nothing to play games with and it's just too distracting. I was quite busy making sure nothing was going up in flames. I cover the ways with stainless foil, wear a welding jacket and of course full face protection. I clip a piece of thin plywood over the handwheel and carriage lever -and still, I got one nice little burn (but not too bad). The chips coming off are white-hot and make melted spots in the stainless foil.
It's worth it though, have a look.
BTW, whenever I heat treat a part that cannot itself be tested, I toss in a reference/control piece of the same material. The piece used today was the same diameter as the bearing shoulder on the shaft and about 1" long. It tested-out at RC 53 and I'm guessing the larger pieces (probably) came out between 49-51.
Note that the KoolMist is not pointed at the part. You should not use coolant with ceramic bits. The tips turn orange hot and a drop of water would probably blow them up.
... They ring like a bell for 30 seconds. My son's girlfriend is kinda "artsy/musical" and I swear, she was driving me nuts tapping on them for 30 minutes...
Ray
Thanks for sharing. Very nice looking roller.
It's impressive that you could role such a thick piece of material.
I was concerned that it wouldn't pull such a heavy piece through without all three rollers driving.
Ray, lots of interesting info in this thread, can you expand a little on the ceramic inserts? I assume they need a very rigid lathe and some horsepower, what sort of sfm, feed and.doc do they take, and are they positive/neutral/negative rake etc?
Thanks, Dave H.
I hope all of you experienced machinists out there like Ray who take the time to share with us others have some idea what that means to us. I'm not quite sure how to express it other than thank you. I would be reinventing the wheel for years to come were it not for your sharing. Nice slip roller by the way!)
