- Jan 26, 2011
- 632
Vince,
The apron was working good and looked good so I did not tear it down, but I do remember some spring clips on the inside shafts that fit into a groove. My main problem with the lathe was the gearbox being stuck and not moving at all because of the oil was dried up and the taper pins on the shafts were facing the wrong way, so I had to rotate the gears to get the pins out and do a teardown, clean and paint to get everything working again. The headstock was easy to take apart. First remove locking nut on the banjo side of spindle then put a piece of plywood on the bed under where the chuck should be and knock out the spindle toward the tailstock using a big block of wood and a big hammer or make a puller with a rod thru the spindle. There is a keyway on the spindle so when it moves it can go easy and move fast and land on the bed. Remove bolts and gears that might be in the way and the backgear shaft. The gearbox is tough to work on because of room inside of it. If you do take it apart right now be aware that the tumbler arms are right and left and the shafts use taper pins. I hope you get the gears fixed before too long.
Bridgeville has been cold all winter with a little snow every other day it seams and just north or south of us has been getting a lot of snow. I live about one mile south of Bridgeville off Washington Pike on Melrose Court, your buddy should know the street. Let me know when you are coming up this summer. I know in July I will be going to Columbus for a few days to a big car show and might have to drive one of the classics to there.
Paul
http://vintagemachinery.org/mfgindex/detail.aspx?id=1617&tab=3 Serial no. 186,514 is from March 1947 and 150,000 is from 1944 after 47 they used the letters after the number like mine.
Paul
