Thanks Kroll, there is very little other SB Fourteeninfo floating around the internet about repairing these machines, so, your story here is quite valuable for explaining how to tear these machines down.
As a post script to your rebuild, i thought I might add a couple of bits of information I learned from tearing my Fourteen down and putting it back together. It's very similar vintage to yours.
- regarding the V belt that drives the Variable speed "Reeves Type" pulley system. It is not actually a Reeves drive, but does function the same way - the top pulley , on the transmission, has a large, heavy coil spring in the pulley housing that forces the pulley closed as the bottom pulley opens and closes. When changing the belt, one should be careful not to unbolt, or loosen the top pulley . the spring will throw parts out all over, and be very difficult to compress back into place. Just leave it alone and open the pulley system to its slowest speed with the drive motor. Then slip the old belt off the lower drive pulley , then take it off the driven pulley on top. Use a 1" flat bar to gently force open the top pulley to reinstall the new belt.
Second thing I learned, - the drive pulley on the bottom is driven by a small motor that turns a stud gear. A small 'counter' device (1"diameter, round blue component in the picture below) connected to the end of the little plastic drive chain, turns 10 times then locks up at the end of its run.
(Edit: this device is called a three terminal potentiometer...)
It is NOT actually a free turning component -it is made with some kind of internal gear or stop that halts its spinning motion at 10 rotations - just enuf to measure the travel of the pulley pulley back and forth to its fullest, and then most minimum extent. So 10 rotations each direction, then stop.
I mention this in detail because IF one takes the pulley assembly out of the frame, and removes the lower unit drive mechanism. This will cause the alignment of the potentiometer to be lost. Resulting in 'over Reving' the little 'Pot' upon reassembly and either breaking teeth off the gear, or spinning the device on its shaft and so breaking the 110v wiring connections off the attachment points. (Ahaha, I've done this twice so far - broke the wires and lost two teeth- until I discovered the rotation thing)
The key upon reassembly is to spin The pot to the full end of its travel, and install in the full open (slowest lathe RPM) pulley position. This will allow the pot to rotate a full 10 revolutions on its shaft, as you increase the speed of the lathe - opening and closing completely with out breaking anything.
The SB Fourteen operator's manual warns about not changing the setting of this drive chain and gear, as "damage may result". But the manual doesn't say what damage might occur, or how to reset the drive gear. I believe, the above description regarding setting the defice limit to the end of its 10 revolutions will prevent such damage.
Well, that's what I've learned so far... hopefully this will,benefit someone else who may take on a SB Fourteen project in the future.
Regards
Glenn
