Thanks guys,
Right now I'm just keeping it simple I have to learn how to use it! It is all oiled up the only thing we did was to take a few light cuts on a piece of 1/2 inch rod stock. Tubalcain has a video instructional lesson series for south bend lathe operations and I am thinking of getting it to ease the learning curve a little.
We have another pulley shaft that will give some more reduction, just by eye it seems too fast in back gear also that would get the motor off the table. Going to setup adjusters on the feet of the table level up the table better and then do the final leveling with finger shims between the feet on the lathe and the table.
I said in and an earlier post that it was missing the apron worm key, I got one off ebay it require a fair amount of grinding and sanding to fit but that worked out and travel is smooth in clutch drive longitudinal and cross feed.
My wife and I are doing renovations on our new old house (before we move in) so since the kitchen is all ripped out. We were able to wrap a sling around a 6' steel beam setting the beam across the joists under the kitchen floor and dropping the eye of the sling through a slot i cut in the floor to hang a chain fall to pick the lathe. How can i tell the wife the beam has to stay on the kitchen floor without getting clobbered?
Bob
