- Apr 6, 2011
- 2,082
Thanks Ron. What makes the 11" a PITA?
Basically, just finding the correct parts. I've been looking for a follower rest for over a year now and have completely given up on a taper attachment (I'll probably make them myself when I get the time.) When you go to look for chuck backplates, drive plates, or faceplates you'll find that nobody makes them for a 1 5/8" - 8 spindle nose. The other somewhat limiting factor is the odd 7/8" through-hole of the spindle. Are you interested in using collets? Do you have the collet setup for the 11"? I haven't seen anyone post yet that has it and there has been a lot of discussion, but no actual proof, of what kind of collets it even uses. The best inference I've seen so far is that they used 2S collets but, like I said, there's been no confirmation of that. The 2S is fairly rare, Hardinge still makes them but the price is enough to choke a guy - https://www.shophardinge.com/productGrid.aspx?catID=1551
With your longer bed (and my 4') the 7/8" though-hole should be less of an issue but it is still there.
That might sound like a lot of gripes but it really isn't as most of those issues can be worked around but can still be a p.i.t.a. at time. :biggrin:
-Ron
