I purchased the larger size that would hold the complete QCGB casting in total submersion. Worked like a charm.
Also made removal of 6 layers of various color paint from the headstock cover as well.
Peeled right off like it was an orange!
Do you have a thread on the go so that I can see your progress?treadmill motors are great, I'm working up a mount and drive for my SB9 right now. A 2hp (real, not TM duty) motor would be a good fit for a SB9 as that'll leave you plenty of power with the speed turned way down. Make sure you gear/ pulley the motor down - they run over twice as fast at full speed than a regular 1750rpm motor. Mine has a 4:1 reduction from motor>countershaft, then 1.5/0.8/0.5 (I'd have to check) ratios from countershaft>spindle.
