- May 10, 2014
- 819
I am not surprised at the glue releasing moisture in 1 hour. Could be the felt absorbing some moisture from the glue then releasing the moisture slowly.
I had glued two pieces of wood for a project with Titebond III. I clamped the joint for about 40 mins or more. I cleaned off the joint with a scraper. The glue line was not visible, only the two pieces of wood with different grain.
I left the assembly on my table saw top over night. The next morning I had a thin line of rust. Drat. Easy enough to remove, but a reminder that it takes much longer than cure time for the extra moisture from the glue to dissipate. Lesson learned. I now lay assembles down on a piece of plastic on the table saw top. I use the table saw top since I am constrained for space and it is the largest horizontal space in my shop which is not covered in "stuff".
