I actually don’t think the reverse ever worked. I have had this machine for years-I haven’t used it in at least 12-13 years, got into other hobbies and it sat in my shop. Memory is foggy so I can’t say 100% it didn’t work, but with how things are testing out I’m going to say it didn’t.Didn't this machine work properly before? Wires don't just reconnect themselves
The problem seems to be clearly in the motor regardless- you've just proven it
I think you should open it up- what say guys?
Really?? Ok interesting.Ah OK, now we are getting to the crux of the biscuit- you should have mentioned that before (like in your first post)
More info is always better
I guess the next step is- I'm not sure.. Have to cogitate on it for a bit
I'm going to take another look at the motor's terminal board- something looked fishy to me
I suspect we may be dealing with a factory screwup that you never noticed
Yes, post 33 I see what looks like vertical straps across pairs of terminals- If those are indeed metal straps that's your problem
They shouldn't be there
-M
LOL.Obviously a factory screwup that went unnoticed and undetected until now- My best guess
Yes both straps come off
You realize you will ruining your perfect record of never using reverse on this lathe- it could have earth-shattering consequences
Yes sir it was new. But also my first lathe. Didn’t know much about any of it.Did you buy this lathe new? Then it certainly was a factory mistake. If one lives long enough one will see just about everything at least once
With the straps there were effectively only two wires to the motor. It takes four to reverse an ac motor (sometimes 3 is enough on 240 volts)
