- Aug 6, 2015
- 3,886
That green is on-brand for Griz — they should crib off your notes! ☺
I'd be likely to spill acetone on the green at some point though, probably after dripping dykem on it... I see that you can get anodized aluminum blank sheets in all sorts of sizes and colors. I had been thinking of engraving 1/8" 6061, filling with enamel, and then face milling it to thickness, but I suppose engraving color might look nice too. So many options!
I just bought an rPi 4 to install linuxcnc to bring my CNC mill back to life, so at some point I should be able to actually finally make my own instead of living vicariously through your efforts.
How were you thinking of cutting them out? Rough cut with a fret saw and file/dremel to the line?
The engraving with this laser is not deep enough to then fill with enamel paint... at least I don't think it is... need to try and see what happens.
I have not thought about how to cut it... remember this is all testing. Plan is to use the one I purchased from Grizzly and engrave that one (yeah, still looking for it ).
If I was to cut these, I think that I would use shears, and then try with a router and using the one I cut out of MDF, as a guide, to trim to size/shape...
