- Feb 23, 2013
- 152
I bought a SB 10L some time ago(6 months) been busy getting ready to move and started dismantling and cleaning the lathe again in between . I'm done with the tailstock, saddle and taper attachment.
However ,I'm stuck on the disassembly of the apron. I have the older version with the star
shaped clutch actuator mechanism. Mostly everything else came off fairly easier. In the manual it was stated
that after the star knob is removed , in order to take out the clutch mechanism the hex nut must be removed
first. In order to do this, it stated to grip the clutch gear from the rear and remove the hex nut. However when
the clutch gear is held the idler gear (which is geared into the smaller gear attached to the draw bar of the
clutch mechanism)still continues to move. I'm afraid that if I'm able to wedge a piece of wood to hold the idler
gear, which meshes with the small gear of the clutch the teeth will break?
One other problem, when taking out the upper rack pinion gear the taper pin was stuck in but
good! I attempted to knock it out but failed after several attempts, I tried to drilled out the taper pin but the
bit broke in the hole(I tried it from both directions and the bit broke in each side) Before I take it to a
machinist for him to try to get the bit out should I attempt it with a carbide bit(These taper pins are a real
Pain in the A$@)-70 + years is a long time to spend in one place !)
Any suggestions would be greatly appreciated.
Thanks...............Razinman
