It seems no different than a 4 way tool post where each and every tool has the shim glued on so that it always comes to the right height.Ingenious I love that design. Great job!
Cutting oil is my blood.
I think your suggestion could work. To make sure the top plate rests on 3 points only, the top plate has to be a bit higher (1 mm longer studs that presses the tool) at the tool side. That way, the unused stud is clear from the top plate.@Huub Buis I think your tool post is brilliant! Beautifully done!
Clearly you have thought this through completely.
The 'engineer' in me makes me want to make a suggestion - in no way critical of your fine achievement - if you don't mind.
Your changeover can be made even faster if you put a third stud to eliminate the need for rotating the top plate. In that way you are always using the same top plate clamp in the same orientation. It will work well as long as there is only one tool in the tool holder at a time.
Not really. With my QCTP, I can only have one tool holder mounted at a time. I can have a tool holder do double duty br mounting both another tool on the back end but that tool would be facing away from the work.That would have happened no matter what tool post you were using.
Not really.
Excellent design! I really like it. It is also pretty forgiving on material and tolerance. I am going to make one or two for my lathe as my extra capacity tool blocks.I changed my tools to swap them in seconds without compromising the regidity of my lathe. After that I changed my 4 way tool post in a 2 way so I can lock the tool with just one handle.
I will make a decent video of my tool post next year. In the link you find a not complete not edited short video that will show how I do it.
My QCTP
