- Feb 25, 2021
- 3,129
What's the diameter of the cart tires?
I'd suggest making sure the lathe is well secured down to the pallet. Bolted down or well strapped. The base of most benchtop lathes are pretty narrow, so it'll tip easily. Once the lathe/pallet is on the cart, strap or clamp it to the cart to keep it from becoming a challenge of moving parts. And consider putting some bricks/blocks under the center of the 2x10's bridging the gap to the porch. Even if they don't break, any sag will just make pulling the pallet across more difficult. Put a lip on the bottom of the 2x10's on the porch side so they can't slide onto the porch with pallet.
Also, consider how you're going to secure the pallet in the car. You don't want it shifting forward on you if you have to brake hard. You may be able to just run a couple ratchet straps out under the hatchback and around the bumper or something.
