POTD- PROJECT OF THE DAY: What Did You Make In Your Shop Today?
Wrapped up 4 pair of lower link mounts for the Cat 0 project.
Need to get 'em painted now.
Looks good!
How did you cut the radius/curve. Looking at tool marks guessing fly cutter, or maybe CNC???
I agree that it is a great learning experience, and I do see it as an important set-up proof for the Clausing after your total tear-down. But on a light lathe, how does one separate the effects of deflection from the conditions of alignment? I would think that two collars on centers would tell you that the tool tip tracks the axis, even if it doesn't account for alignment. Maybe watching a test indicator on the end of the work as a cut is made would give you a deflection value to help keep account. I dunno, it's an interesting metrology question that gets more challenging to address as machines get smaller.
Good points!
Decided to try the two collar approach.
Did not have much luck attempting to measure deflection.
So
Applied some marker, honed the tool and did a couple cuts to establish a new base followed by a .0005 cut.
Measured the chuck side at .9470
Far end at .9478
.0006 larger on the far end then when turned as a contiguous part after aligned.
Back to the question of deflection or alignment as root cause.
Only way I can see forward is to do a series of spring passes, mark ups and measurements.
Four passes later
#1 chuck side .9470
far end .9476
#2 chuck side .9470
far end .9475
#3 chuck side .9470
far end .9473
#4 chuck side .9470
far end .9473
Spring pass #4 was just sharpie ink
Not very scientific and doubtful that NASA will be reaching out to me any time soon.
But good hands on and have some faith that things are aligned now.
Will see how it goes when I chuck up a 3/4 X 3 inch 12L14 rod next.
This time change is killing me.
More fiddling (and making a mess!) on the crane project. The driveshaft is square, because a handwheel drive will move the bridge. But that handwheel will be able to move independently of the chain fall carriage along the bridge. Since the drive handwheel moves, a slip fit 'drive mechanism' (No idea what to call it, but it drives the square shaft...) needs to slide along the driveshaft. I couldn't easily find any receiver tube for the 2" square tube so made that a long bit ago. Finally adding the sprocket and support for the 80mm ID bearing that supports drive mechanism. That probably doesn't make any sense, yet. But it will as more hardware gets done.
View attachment 481993 View attachment 481992
Purple box is a worm gear, w/ a roller chain from that to the square tube drive?
Yep, that's the idea.
It still remains to be seen if it actually works, once all the hardware is built.
Do you have a tenths indicator?
If you measure both ends, then mount an indicator in the tool holder and see what the indicator says.
If the indicator agrees with radius of the part or not, that should help you sort out deflection vs. alignment. The size of each turned section doesn't have to match each other. Just mark out the radius on paper and see how the indicated measurement agrees.
This will probably help you reveal all sorts of neat things to think about when aligning that lathe... :)
For right now, I'm making this.
It's made from a homemade square tube with some 3/8" plate welded on. To support the thing in the lathe, an insert needs to be made to just lightly press into the square tube. So more cutting and milling, and messing up the little mill.
Took a good hour to get everything running true. I really loathe setting up square tube a 4 jaw chuck. It's not hard, just tedious. Here's the parts, just before heading to the lathe.
And finally, making a few chips. Interrupted cuts, cuts through weld, being driven form the far end and supported with a live center made me nervous. Just took light passes, hand feeding everything. Stopped 40 thou shy of the final cut. Since a bearing fits over this, figured letting it cool for the night before cutting to final dimension wouldn't be a bad idea.
Edit: Here's a bit more context into how this fits the drive wheel mechanism. Not everything in the gold colored support carriage is fleshed in there yet. Some additional rollers are missing from these views.
Have you seen the crane build on RC Groups? I will go look for it.
