- Jul 20, 2012
- 1,238
Would it help sort it out by unplugging it, turn the switch on then plug it in so the connection is at the plug and not the switch with the possible unreliable contact?
see if this helps.As a reminder I (poster) am not on a GFI. I have tried the machine on two breakers and neither are GFI.
Today I rewired the machine to remove the contactor, e-stop, chuck guard, on/off switch from the circuit. I provided always hot power to the control board. This keeps the F/R switch, speed pot and tach in the circuit and operating as intended. I turned the machine on/off using a power strip. No breaker tripping.
In order to continue isolating components I would like to have the correct wiring diagram. The current PDF on PM's site does not match my machine. Does anyone have an older diagram for this machine, approx 2019? Current manual is stamped "PM-1030v v5 2020-10"
