PM1030 tripping breakers on startup
It seems that it has not even been established that there is an overload in the form of a very short pulse. If I were diagnosing this problem without a logging device, I would just get another circuit breaker put it in line. Actually, I would just use an automotive fuse in a hacked line cord duct taped to a junk 2x4 and watch it like a hawk. If you are drawing 2.8 amps and blowing a 15 amp breaker without seeing anything on the meter, it is a pretty massive overload like 40 amps. If a little fuse doesn't blow, I would take a good hard look at the breaker. I have found that a 15 amp breaker can take 25 amps for several (tens) of seconds before it trips.
Thank you everyone who has responded.
I have done the following:
-Replaced breaker with new GE 20amp. Same results.
-Tested circuit with a 4.5hp shop vac and 1500w heat gun. Using these devices my clamp meter shows WAY higher readings (~10amp) than I ever see from starting or running the 1hp lathe. No trips.
-Swapped another control board that came with the machine. Same results.
-Removed power out to motor connection from control board (3 pole green connector on left). This leaves the big control board caps in the circuit. I still get trips like this.
I do not have a way to log momentary inrush current. I did just purchase a small 1 channel micro scope but do not have a current probe for it as yet.
Here is a photo of the control board. I believe it to be similar to: https://www.aliexpress.com/i/1005001279538818.html?spm=2114.12057483.0.0.42804074F0RaE0
I hate when they flood the board with black epoxy, makes it almost impossible to service.
I know it is the idea, but I still hate it.
I cannot possibly see how the issue with anything besides the board. To rule out the power cord at a friends suggestion I wired to the spare board directly with absolutely nothing else connected as you see here. I turned it on and off with a known good surge protector. It still tripped breakers on two separate known good circuits one is 15 amp the other is 20 amp.
Is it possible to see the other side of the board if taken off the heat-sink ?
PM is being helpful and reading this thread, I wanted to do all I could before calling back. Neither of us want to throw parts at the problem.
The board is fully potted including the screws that retain it to the heatsink.
sounds like a ground fault or internal short within the board. How much is a new one?
