- Mar 26, 2018
- 8,409
Good for you!!I just placed and order for a Hypertherm Powermax45 XP
Oh man, that's a bummer. Once you pull the plug on a new machine you want it now!!Thought I would give an update. I am still waiting on the Powermax45XP. I ordered it from BakerGas and It seems that it is backordered now and Bakergas can't tell me when it will be available. It looks like it is B.O. from other suppliers as well so I will just be patient. (not my strong suite)
I think you could buy or make a desiccant drier without breaking the bank. The desiccant can be dried out and used over & over.I can't see putting in an active moisture removal system just for a limited amount of cutting per year.
I have Desiccant beads in my air supply line. Even with climate control in the shop, they only lasted a week before I had to dry them out. Too much work.desiccant direr that holds about a gallon of beads. They turn color as they gain moisture to tell when to change
The shop down the street used a desiccant drier for their laser machine. Worked fine. But they, like all things need to be sized for the application. Theirs had two tanks about 6' tall and automatically switched between, so one was in use and the other drying. The gallon+- sized ones on our machines are backups incase the refrigerated drier has problems.they only lasted a week before I had to dry them out. Too much work.
I know you said that Hypertherm is out of the running but just in case you change your mind, There is a special tip available that directs the plasma out at a 45 deg angle, that along with holding the gun at a 45 deg angle means that you can cut out a weld on a 90deg joint and leave the structure alone (in theory). I have not tried this (still waiting on my Plasma Cutter) but they have a video showing how it works. looks real handy.I'd like to be able to blow the welds away here parts a joined at 90 degrees.
