- Jun 17, 2016
- 348
Thanks General. As I think that my usage will be sporadic, higher consumable cost will not be as big an impact as if I used it daily but I'll be sure to look at the cost. I don't have any extra special air dryer for my air system but have thought of building a DIY copper loop dryer at some point.
I appreciate everyone's thoughts and suggestions.
I think those copper systems are fine for general purpose air tool use, and you can condense a lot of water, but you will still not be able to take out water vapor from the air at ambient temperature unless you have either a refridgerated air dryer and/or a superb desiccant dryer system. Think about it---the air before entering your compressor is at ambient temperature, yet it still holds water vapor; the water simply does not condense on it's own and drop out onto the ground just because it is "ambient", right?
