- Jun 12, 2014
- 4,817
Most likely your gear head will take less than 1 gallon, usually ISO32 is recommended unless you are in a very warm environment. Gearbox and carriage are typically ISO68 oil viscosity and will take probably a quart on your size lathe. I use Miles Hydraulic R&0 oil's, you can get a 5 Gallon pale for around $92 shipped and sign up for their email and get 15% off, I routinely get 20% off emails from them. Multipurpose R&O Oil is a rust and oxidation (R&O)-inhibited, anti-wear circulating oil developed for use in circulation systems, centrifugal air compressors, geared turbines, lightly loaded enclosed gear drives and many other industrial applications. Many hydraulic systems will be shared with gear drives, and the oil may be used with gears that do not have high loading. There are some difference in gear oils vs. hydraulic oils, but in a smaller lathes it will make no difference. Condensation will occur over time, so a regular (annual) changing of the oil is more important as to longevity.
D-A Lubricant Co D-A R&O Hydraulic Oil ISO 32 - 5 Gallon Metal Pail 54719 | Zoro
Order D-A Lubricant Co D-A R&O Hydraulic Oil ISO 32 - 5 Gallon Metal Pail, 54719 at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.
www.zoro.com
Miles Lubricants 5 gal Rust and Oxidation Oil Pail 32 ISO Viscosity, 10W SAE, Amber M0010020103 | Zoro
Order Miles Lubricants 5 gal Rust and Oxidation Oil Pail 32 ISO Viscosity, 10W SAE, Amber, M0010020103 at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.
www.zoro.com
Miles Lubricants 16 oz Gear Oil Bottle 68 ISO Viscosity, Slight Yellow Tint MSF1303007 | Zoro
Order Miles Lubricants 16 oz Gear Oil Bottle 68 ISO Viscosity, Slight Yellow Tint, MSF1303007 at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.
www.zoro.com
Miles Lubricants 5 gal Gear Oil Pail 68 ISO Viscosity, Amber M00600103 | Zoro
Order Miles Lubricants 5 gal Gear Oil Pail 68 ISO Viscosity, Amber, M00600103 at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account.
www.zoro.com
