I have an Enco 12/36 model 110-2031 built 1991 and have never changed the oil. This is a hobby lathe and 30yrs does not truly reflect the hours on the machine but it is due for a change. With that said one reason for not changing it is that I cannot find a drain plug. for that matter there is no fill plug either just oil holes over each end of the spindle. Someone suggested removing the site glass to drain the headstock. I tried prying on it with knife and it moved like it might be pressed in with an O-ring which would be great.
The next question is what type of oil to use. The owner's manual list "SSU 100'F 160" not sure what this is. Can someone suggest something I can order via McMaster?
