- Jul 26, 2013
- 584
Good morning, Carroll
Where you have a wood lathe, I suggest that you make a driving dog out of wood to drive the shaft. Maybe glue two layers of 3/4" plywood together, bore it out close to the OD of the gear, split it down the middle and then contour the outside so that you can run a couple of bolts through each side to act as a clamp onto the gear. The drill for a bolt at right angles to the clamp to act as a driver against one of the chuck jaws.
Here's a crude drawing to show what I mean...
I think this method would be kinder to the teeth on the gear and provide enough drive to do your cutting, as long as you take light cuts.
Brian
Brian
