- May 17, 2015
- 165
Hi Kroll. In my thread about the harmonic vibration in my lathe i have the exact same problem with oil leak on the input shaft and a failed bushing on the pulley end of the shaft.
I ended up buying 2 sets of needle rollers with the press fit inner race. I machined out the housing to take the bigger OD of the outer race and had to turn the shaft down for the inner race slightly. The sleeves get over the hardened shaft issue, and from memory it was very soft for a shaft any way. I speedy sleeved it for the seal.
Come out very smooth running. After lots of searching for equivalent parts it was easier to just make modern bearings fit.
I can see it i can find the bearing numbers, although yours is a smaller machine, there are so many differences among the same models over the years i dont think any parts manual is accurate.
