- Jan 21, 2021
- 452
Ah! Good spot !! Close to the harbor too! We go there ever weekendI'm a stone's throw away in South Morro Hills. Dave, my neighbor behind me moved in a little over a year ago, and he was from Vista.
We've got a JD tractor with calcium-filled tires here in western Oregon and rust is definitely an issue due to the almost-constant humidity in the winter. I had to replace the valve-stem guts to keep air (and calcium solution) from leaking out through the valves. Valve stem caps with seals are a good backup. It appears that garden-variety Schrader valve-stem parts aren't all that resistant to corrosion, so a backup is a good idea.My records show I bought new rear wheels for my 2002 Kubota B7500 in 2015 with 700 hrs on it as the wheel around the valve stems was badly rusted from the calcium chloride fill. Yes I had inner tubes, rusted anyway.
To be fair I live in a wet climate, but Mr. Orange is kept in a dry barn when not in use.
At the time the dealer nearest me did not fill tires. They told me they take them to a tire store, that’s what I did.
I used beet juice this time.
Also the b7500 (same tractor as MMCMD has, but couple yrs older) has rear hubs that are adjustable each for 3” width. 6” total. I leave at widest, as I also have hilly property.
For reference my manual states to always have a seat belt on if the ROPS is up.
If the ROPS is folded down, or no ROPS, do not wear the seat belt.
As always YMMV. Cheers
Put them on yesterday. And I found the rear tires are loaded, but maybe only 25% or so.Holy HELL ! With a grader box on the back yet ? I can pull the rear wheels out 3 " but it put's out past 48" . My rear tires are filled , and I can add weights on the ass end , but she still wasn't up to a Johnson bandsaw I tried to lift . We won't talk about the post hole digger .........................
Is/was that a BX , B or and L series ? I would like to move up to a 40 HP L model one day if I get up north . But regardless , that's a downed Bota , which I hate to see .
They're only good if they work with all your attachments, otherwise you lose the "quick" when you need to keep taking the Qhitch off and on along with the implementThe QC hitch is a good idea but doesn't work all that well. The top hook won't line up to some implements, the width has to be correct, and the top member hits the drive shaft on some things. Have one but quit using it.
Greg
