- Oct 7, 2020
- 2,116
Man, Your Airstream looks great! Looking forward to seeing the solar project come together.
Thanks for the validation and all the great back stories.Just a thought; keep as much material as "universal" as possible. When traveling and something breaks, you will pray that a replacement is easy to find. Bumming around on a motorcycle a few years back put that in good perspective.
i
The copper buss bar stock, at 3/4 X 1/8 is a fairly common size. A few years back, I put a rectifier bridge on a Lincoln buzzbox. The buzzbox was rated at 225 Amps, I used 500 Amp diodes. And 3/4 X 1/8 copper buss bars. The buss bar stock is a good choice, of sufficient size to take abuse. And abuse there will be. . .
Thank you.Man, Your Airstream looks great! Looking forward to seeing the solar project come together.
While I'm not familiar with that location, that would be a dealership that sells Airstreams. There is only one manufacturing location, and that is in Jackson Center, Ohio. Airstream popularity has had a huge resurgence that began before the pandemic, but really took off, as did other RV sales during 2020. I'd wager that most of the Airstreams you see at that dealership are already sold and awaiting pickup.There's what looks lik an Airstream factory [ or at least, a major dealer]next to Loop 202 in Chandler, AZ, about a mile from where I live. I pass by it when I'm returning home from downtown Phoenix trips, but haven't ever gone in there.
Wow,That looks a like a very big dealership. Plus they have two locations. Man those babies are pricey and most of them are preowned.@PeteW - You're absolutely right about this being just a dealership. Here's a link to their website:
A general rule of thumb for metal work is to have at least 2 teeth in contact with the work. 3 is preferred, 2 will work. Copper is a soft material, so there will be a little "give" in that rule of thumb. Further, a band saw will have adjustable pressure in the cut which will also add a little "give". I personally would use a 16 pitch blade, but that's just the way I do things. And what I have already mounted on my saw. . .
You strike me as a novice in the metal working portion of the project. I will treat you as such. . . Cutting a bar in "half" and then resetting the clamp (vise?) for two pieces will cut down the time a little. Doing it again is questionable, depending on the length of the bar. Starting with 2 pieces of bar stock doubles that again. Think binary arithmetic. . .
I started a similar project a few years back, on an older Avion. A '72 model of 32 feet with intact skins and a fair interior. It started out as a remote worksite "office" with a place to crash. Then I got into the details of how it was constructed and couldn't bring myself to take a "sawzall" to the body. It ended up as a personal project, and then God came along and started slowing me down, with strokes. I kept going until He put me in a chair.(wheelchair) So, OK, I slowed down some. At age 66, I suppose it was time to slow down a little. I ended up selling the project I could no longer pursue. It went for less than I had hoped, but somewhat better than scrap value of the shell.
In any event, the Avion had a matte finish, unlike the Airstream's mirror finish. I liked the matte finish originally because I could paint it in company colors for field use. That all got set aside when I found out what I had. I didn't shoot for a "restoration", just a refit using more modern materials and appliances. Such as the "mood" lights. . . I used LED strings and dimmers in the forward area. And LED marker lights. And my own devised back up lights, some serious trapezoidal beam tractor lights. And moved the battery box outside to the hitch. As stated, I am a little allergic to batteries, especially Lead-Acid which are bad to gas.
I'm sure that somewhere I have the drawings for both the 12 volt and the 120 volt schematics. But they are on an older drive from an XP system I was using (and prefer...) and I don't feel inclined to search for them. Hence won't offer them. The best I can (and will) offer is advice to consider more modern parts. Don't make your's a restoration, make it livable by today's standards.
