- Nov 21, 2012
- 793
My previous Lathe was an Emco Maximat V10 and although a very good lathe, was a little worn and too small compared to my mill. I wanted the lathe and mill to compliment each other and be of similar size and weight in order to have them produce similar quality results (all dependent on the operator of course). This lathe is a huge step up as it weighs 4 - 5 times more than the Maximat and has a clutch, mechanical variable speed drive, spindle brake, powered cross feed and camlock chucks. Add to this it's rigidity and it's in an entirely different league to the little Emco. For those interested there are more details here:
http://www.lathes.co.uk/chipmaster/
I saw this lathe advertised in Sweden while on vacation visiting family in Australia. I rang the company and told them I wanted it and assured them I would take it if they held it for me. I periodically rang throughout my holiday to make sure they didn't doubt my intentions to buy the lathe. I arrived home to Norway on a Wednesday and then drove out on the Friday night to Sweden. In total I travelled 1300 km which took 18 hours for the round trip. I was happy to do this since the mechanical condition of the lathe was extremely good. There was no bed wear that I could see and the original precision grinding was still evident on the ways and sliding surfaces. Add to this that it came with a host of accessories, including a full set of change gears and it turned out to be a bargain despite the required travel time and distance.
At this point I am in the process of converting the electrical from 400 volt 3 phase to 230 volt 3 phase. This requires changing the motor to Delta config and replacing the magnetic switch since the no voltage safety and overload protection are not suited for the lower voltage and higher amperage. I have attached some pictures since this machine is hard to find outside of Europe and the UK I figured you may enjoy some photos.
Paul.
Paul.
