- Sep 28, 2013
- 4,306
thanks guys! I very much have a soft spot for my 618 and it'll make a great lathe for someone when I finish putting this together, but I am starting to bounce up against its limitations. Mostly the through spindle clearance and bed length, plus the minimal tail stock ram travel, but it is a very capable lathe for its size. I can't wait to get the SB up and running though, it's going to be awesome. Silverhawk is right - these were a short(ish) run odd ball lathe before the SB9 workshop (A/B/C) came out in '34 or thereabouts. They have a "heavy" 10 (10L?) bed with a downsized head and tailstock. Bed is 7" wide compared with the 6" of the workshop (I think, don't have one to measure). Spindle height and spindle nose are the same as the later 9" lathes (1 1/2 - 8tpi, 3/4" through hole), therefore backplates from later lathes fit but the steady won't. So you can actually make a heavy 10 out of it if you found an appropriate headstock and tailstock, which is pretty crazy.
Currently working on the tail stock, putting in oil galleries.
3/16 brake line, with the end turned down to 5/32 (longest drill I had of about the right size)
cross holes drilled, opened up to 3/16 on the flat way side and pipes pushed in
I've drill and cut oil grooves, but haven't taken a picture of that yet. Also realised while lying in bed this morning that I have somewhat painted myself into a corner as the carriage wing can extend past the front of the tailstock. So I'm going to have to make oil cups that have an angled bottom to clear the carriage
