- Mar 21, 2013
- 4,067
I would not be worried about cnc kits. It's a mill, you can make that... What I would like to know is how it cuts steel. What kinda DOC can you get. When I was looking I could afford a cheap used bridgeport or a smaller bench mill. So the 704 and the 25 and 35 or what have you was on the list. RayC more or less talked me out of it and I got a bridgy. I was told they are not meant for steel and they would no longer carry them once they were all gone. Which concerned me for parts and the machines ability.
Hey Chuck,
Ray C was telling me about people who were buying these machines (PM 20/25/30) and breaking them in the first few months because people do stupid stuff like try to drill 1" holes in steel, or using 3/4" end mills to hog steel on these mills. Seriously? These things are not a BP, or even a RF45 for that matter so Matt and Ray were having to fix/replace overabused machines left and right (in my opinion, they shouldn't have fixed anything that was abused). Hence the desire to NOT carry them anymore. Can't say as I blame them either.
The only thing I can say is that the machines do very well, if you stay in their performance envelop. Largest job I have done on mine (it's soon to arrive Big Brother will handle the heavy stuff going forward) was I needed to cut a brace profile in 4"x5"x1" steel. I basically buried the endmill (solid carbide 3/8" coarse rougher) but took three passes to reach full depth of 1". I kept the feed fairly conservative and the chips coming off had a slight blue tinge to them. The mill performed flawlessly except for the aftermarket pulley kit I installed. Apparently, it wasn't designed for this heavy of a cut. But the rest of the machine took it all in stride. I wouldn't recommend a steady diet of jobs like this, but the machine will handle the occasional heavy job if care is taken. I will address the shortcomings of the pulley kit soon.
I've cut pretty much everything so far in mine e.g., steel, hardened steel, stainless, and titanium. The biggest requirement with these smaller mills is to not over do it. Heck, I was milling forged 1911 slides for Bomar sights using a tiny Sherline mill and turning/threading Barsto barrels at 40 tpi on their little lathe. I wouldn't recommend most people tackle that, but it can be done.
My point is that these machines can do some really good work if some thought is put into the job at hand, or you can break 'em left and right. Comes down to the operator I guess.
EDIT: With the changes to the drive system, e.g pulley and belt and BLDC motor the shortcomings of my version are overcome. The newly designed vertical column is just icing on the cake.
Bill
