Hey y'all, I need to make this project happen ASAP. Got all the machines to do it with, just would like to get some pointers before I start. All opinions appreciated
I got a Greenerd Manual arbor press I would like to use for the basis of this set up. This press weights about 300 lbs and easily punches this mild steel I need for this job. A friend of mine told me I could use is Roper punch if I could find the correct punch and die. I called every where. $200 and upwards. That ain't gonna happen. Hi-ho Flea Bay. I scored this punch and die for $25 free shipping. I need to make a fixture to punch holes in 16g mild steel. I tested a piece of shim stock and my arbor press does it with no trouble.
So, mu project is this. What do I need to do to set this up in my arbor press ?
Die is .540" thick, with a .125" locating dowel pin.
Die diameter is 1.562"
Square punch is 2188." (7/32")
punch has a .625" shank with a .625 square , end is threaded looks like 5/16 NC
y'all help me build a fixture to make this function !!!! Got a lathe and mill, welders, grinders, whatever I need
Thanks
Mutt
Thanks
Mutt
