- Dec 18, 2019
- 6,464
Gives a lot of rigidity to the cut. Also ensures that you won't ever wear it out! Blade is reversible, as I recall.Sorry, not meaning to hijack the thread but - That blade is HUGE - what is the purpose of that?
You just grind the top of it to resharpen. Never need to replace it.Sorry, not meaning to hijack the thread but - That blade is HUGE - what is the purpose of that?
+1 on the Aloris HSS threading tool. I use the carbide insert ones and the Aloris, tend to go to the Aloris. I bought mine (BXA size) new off eBay for $125 around 5 years ago. They're probably closer to $150+ now. I bought the carbide insert ones for under $25 including 10 inserts. Yeah, the tips can chip, but the inserts are cheap. It depends on your budget and if you don't mind a little potential downtime having to replace the carbide inserts (though with care they do hold up).
Bruce
I was just planning to stone it flat until the top edges were restored. Don't have a surface grinder, so I need to take it slow and easy on a flat stone. But I haven't had to stone it yet, it still cuts threads very well.You just grind the top of it to resharpen. Never need to replace it.
I'd agree, since that comes with a blade. (Probably a P10.) That's cheaper than when I bought it during pandemic times.I just checked eBay, $120 for the AXA8. Seems like a bargain.
Aloris AXA 8 Threading Tool Holder USA No Blade for sale online | eBay
Find many great new & used options and get the best deals for Aloris AXA 8 Threading Tool Holder USA No Blade at the best online prices at eBay! Free shipping for many products!www.ebay.com
I cut a 3/4-10 using the 16ER-AG60 with no issues.There does appear to be some side relief, but no where near what is called out when grinding a HSS bit. I see maybe ½º to 1º of side relief. I guess that the inserts would be okay for larger diameter and higher TPI stuff, but the smaller diameter and lower TPI stuff may require a re-look.
Surface grinder?! We don't need no steenkin' surface grinder! A bench grinder will do the job.I was just planning to stone it flat until the top edges were restored. Don't have a surface grinder, so I need to take it slow and easy on a flat stone. But I haven't had to stone it yet, it still cuts threads very well.
Honestly, a touch up stoning will work fine, since the blade doesn't wear quickly. Too easy for this beginner to mess things up with a grinder, so I take it slow and easy.I cut a 3/4-10 using the 16ER-AG60 with no issues.
Think I got a P4 from you a while back. Works great.I have a couple Aloris blades here and I sold all the holders . They've been packed up in a small flat rate box for 2 years I think I think 2 P4s and a P6 if I remember correctly . Somebody on here said they wanted them and then I never heard back from them .
