- Mar 30, 2014
- 115
Been a hobby machinist for several years now. Made lots of stuff, repaired stuff, modded stuff, etc...
Threading is one thing I have only done once, just to see if I could. The threads worked, but I doubt I ground the carbide tool to the exact shape it needed. It was just on a piece of scrap.
Anyways, I want to start doing this more, as I want to become capable of doing it properly.
I have lots of pieces of brass, aluminum, and steel rods to practice on to get good at it long before I do anything that matters.
I want to use a indexable carbide insert type tool. I do not want to fool around with trying to hand grind a tool and worry about getting the angles correct.
All the threads I plan on cutting are standard US/imperial threads, right hand. 1/2-28, 5/8-24 are the two major ones I want to do, but also 13/16-16 may be on the roster.
My tool post uses 1/2in square shank tools.
Looking through shars, I see several different toolholders and I am not sure what one to pick.
Can anyone help recommend one?
Here are a couple I saw. Naturally I want one with inserts available to cut the threads mentioned above, but also have inserts for most all common/standard threads (like would be in a US/standard tap/die set)
Not being up on the lingo of what all the different letter/number codes translate to, I do not really know which one would be best for my needs.
I'm thinking the first one?
https://www.shars.com/products/inde...ool-universal-external-threading-toolholder-1
https://www.shars.com/products/inde...nal-threading-grooving-tool-holder-right-hand
https://www.shars.com/products/inde...08-2v-notch-threading-and-grooving-toolholder
