Hi all! New here. Interested in all things gearhead and garage related.
I am mainly a motorcycle guy and occasionally fabricate small, simple parts. I have only a TIG welder, band saw, angle grinder and small drill press. Space and funds are limited but I came across this older South Bend 9" and grabbed it. Serial number 74038. It appears to be a pretty simple unit- no gear box and no, I did not get any gears with it.
I've started taking it apart and cleaning it. Seems to be in decent shape though as newbie, I don't know exactly what to look for. No excessive, corrosion, though. It is missing the clamping plate and bolt for the tail stock and any centers for the tailstock but I have already ordered those parts off of an eBay seller. I love the way these things are built- so matter-of-fact and simple.
I was advised to get a kit like this with the oils and felts and such. Would you agree? https://www.ebay.com/itm/South-Bend...ackage-Manual-Felts-Oil-Grease-/152525013342?
_trksid=p2349624.m46890.l49286&fbclid=IwAR2KFVnKk4GD1wHGaOT8usdiIgQ0VWtdo1i--YKNjIW-sWoaW8VW4fLIeng
I probably won't worry about a quick change tool post for a while. Still have plenty to learn. I have not used a lathe since high school and that was DECADES ago!
There appears to be a couple heavy layers of paint brushed on, at least.
That plaque that is pinned to the bed up by the tail stock- mine is covered with thick paint. Is there generally a model number or other information on the plaque? Is it engraved and should I use a paint stripper to clean the plaque up? Or some other method?
Thoughts and insights appreciated! Can't wait to start tinkering with it!
