Have a problem now I'm unsure of how to solve. Usually I can figure things out and come up with a solution.
The first time I started the engine I couldn't get it into gear. I thought about it and figured the clutch was stuck because it was sitting so long. It is a used clutch I picked up with the flywheel and bell housing. It looks very good, lots of meat left on the disk, no evidence of it slipping. I put it in gear with the engine off and started it and it worked fine.
So after the first test drive I couldn't get it into gear again. Did the same started it in gear and it worked. Took another test drive yesterday and the same thing. I need to take it down to get an alignment and it's a 60 mile drive round trip and I don't want to be broke down with it or damage the trans trying to get it home.
Did a lot of research and people are finding that the pilot bushings now are made in china and are too tight on the input shafts cause them to drag. So I bit the bullet and pulled the trans and clutch out. I can't see anything wrong. What I thought was the problem (pilot bushing) seems fine. I have an extra input shaft and it fits in the bushing easily. From that I can measure there is a .003 clearance and no signs of seizing or galling. In the olden days you used to be able to dial in a bell housing with the clutch pilot bushing. No way to do it with the design of the bell housing on this.
So I think it could be one (or more) of 3 things. The clutch, hydraulic release bearing, and clutch master cylinder.
The clutch (when I can get it in gear) grabs at the very top of the pedal travel. This seems to be consistent when I am able to get it into gear and drive it. So I really don't think it's the hydraulics or transmission. I've had this trans in a different car and there is no problem with it at all. Shifts great, it's just when I'm done with the test drives is when I can't get it into gear. So I do the start it in gear thing and it works again for a little while. I'm leaning towards it being the clutch. A new stock style clutch kit with flywheel kit is about $360. A hydraulic release bearing is $75. Clutch master is $70. I'd like not to have to pull the trans again and if I just replace the clutch I might have to pull it to put in a release bearing.
So I'm not sure what to do. I know your guys aren't here to help, but sometimes writing it down (so to speak on here) helps my thinking process. And it doesn't hurt to see what you guys think. I want to figure out the problem and not be just a parts changer.
So, ideas?
A quick side note: My wife is getting smarter about car stuff. (She has been around me to long) Anyway I was taking off the bell housing and hit it on something My wife asked is that the bell housing? I said yes, how did you know. She said it rang like a bell when you hit it. So now I know why its called a "bell housing"
