- Aug 30, 2012
- 105
Here are some pictures of a light I made to go on my Grizzly 705 mill spindle. First picture shows the shotty job of soldering the LED's but also shows that the inner two rings of lights are tapered at 25 degrees to point them at the tool, the next twoo rings are straight down to flood the area around the work site. The second pictures is the front showing the array layout. Next we have the side profile showing the height of the whole assembly of two inches. It could be a little shorter but for my mill no longer. Last we have the larger ring that clamps to the main spendle housing with three set screws.
I will try to get pictures of it in operation but until then you have to take my word for it, it works great. Lots of light and no shadows since there are LEDs all around the tool bit. It is powered by a 9volt 1 amp wall charger for a radio.
Turbo
Turbo
