- Feb 7, 2013
- 2,489
Thanks, I'll check this out.
Thanks. That doesn't seem to be the issue; I checked the stop and it doesn't appear to be sticking.
No bulb. That's an odd feature.
Brushes look fine.
I have seen where the brushes on first inspection look fine but the springs have reached the wear stop that keeps them
from putting adequate pressure on the commutator. I'm not saying this is the problem but one needs to
look it over and verify that the springs are indeed putting pressure on the commutator. Some motors are made
this way to protect the commutator when the brushes wear to the wear stop.
Another thing that comes to mind that would cause the symptoms mentioned would be the variable speed control
resistor. Inside it is generally a carbon resistor with a wiper that can be problematic. I'm very careful about turning
my speed control any more than necessary since turning it eventually will wear out the carbon part.
