- Feb 1, 2015
- 9,622
Has the table stopped moving but the motor still runs? If so, stripped gears are a possible cause. If a set screw is used rather than a key, i5t may have loosened. If the motor stops after a revolution or two, it may be an open winding on the armature. A slight rotation of the motor shaft will start it running again bur as siin as a load is put on the motor, it will stall on the open winding again. Past that, you get into the speed control wher a number of faults can cause your problem.
