- Jul 29, 2014
- 2,737
In a similar situation I would have no trouble ditching the radial arm saw.
That is a fact of life for me doing any kind of home project. Everything takes 5x’s longer than I think it should.Didn't get as far as I hoped today before the heat drove me inside. Something always seems to get in the way. Like finishing installing the drip emitters for the front yard landscaping. No more hand watering. Yeah!!! And removing some supports along the edge of the deck. They were screwed on. How time consuming can it be to remove a dozen or so screws. Took forever to remove them. Got the new support for the edge of the existing deck installed and one of the corner support blocks in place. Wonder if I will get the rest of the support blocks and floor framing done tomorrow before it gets too hot to work.
View attachment 414148 View attachment 414149
I have that same attachment with my original Proto tool set. If feels like I’ve lost a family member when I lose one. I don’t have any big machines I’ve had that long luckily. But doing the kind of work you’re doing with the shed I would rather use the RAS than tablesaw.I bought the radial arm saw new almost 40 years ago to remodel a previous home. It has served me well over the years and is an old friend that I can't part with.
Tomorrow I start on the shed. It will be 10' wide by 12' long. 6' from the back door of the garage to the shed. The 6' is required by building code so that I don't have to get a permit. There is an existing wood deck off the garage that I will be extending that will be the floor of the shed. The shed is mostly for storage. Won't have electricity to start with. Again to avoid having to get a permit. I will start post pictures tomorrow. Hope to have it done by next Thursday.
The dirty stuff will go in the shed. Bench grinder, belt sander, band saws, wood working stuff, etc. I will have to use extension cords. Haven't figured out how I will arrange the table saw and radial arm saw. I am thinking about having the table for the radial arm saw at the same height as the table saw. I am also thinking about putting the table saw on wheels since it will be taking up space in the middle of the shed.
The garage will house the lathe, mill and drill press for metal. Have started looking for a flat file like C-Bag just posted about. Don't have room for the all of the rolling cabinets that I have. And the main one with my machining stuff is bursting at the seams.
