- May 3, 2017
- 1,997
Okay, I'm pretty whupped tonight, but I got a lot of cleaning done. Here are some photos:
1. Got the base cabinet cleaned up. The top drawer is removed because the single hole in the back is bolted to a threaded hole in the rear of the shaper from inside the cabinet. One challenge that became immediately clear - even the mildest cleanser that worked was taking off dirt, grime and, unfortunately, paint. Here are some before-and-after shots.
2. I disassembled the ram and the knee, cleaned the ways, and some additional cleaning done. I had to make a judgement call: because so much paint was coming off, I decided to clean painted surfaces as best I could without doing a deep cleaning. Ideally, I should break the machine all the way down, sand blast the parts, repaint, then reassemble. But we're not trying to make a showpiece - just a nice machine to use.
A little difficult to tell from the photos, but the ways on this shaper are quite literally brand new! All the factory scrapings are visible, there is no evidence of wear, and everything is tight.
3. I will probably mount the shaper back on the cabinet tomorrow and then start reassembly of other components. They're resting comfortably and soaking in kerosene right now.
4. I'd like to take the handwheel and pulleys off to clean, but I don't have a puller that fits the wheel. Any suggestions?
Regards,
Terry
Regards,
Terry
