Congratulations! That's a fine piece of equipment. I got one just like a week or so ago, I'm pretty impressed with its power and quietness.
I got the optional speed display with mine, held on with three magnets. I was really pushing the machine, side milling some cast iron with a 3/4" bit, which caused some pretty heavy vibration, and the speed display slipped, looked like it was soon to fall off. The metal that the hold magnets grip isn't secured very well, but a couple of pieces of Industrial duty double sided tape from Home Depot fixed that issue!
I also got the power feed kit, which works well, but the cords drag pretty bad on the bench top (both cords come out the bottom of the control/motor assembly). I went to Home Depot and purchased a 2' x 4' piece of 3/4 MDF (near the plywood section), had them cut off a 12" x 24" piece off one end, and mounted the mill on that. If I had it to do again, I'd put two pieces under the mill (I think my bench is a bit light, only 1 1/2" thick without the MDF), but this works OK for now.
So far, the mill has been flawless, and I've worked it pretty hard in the short time I've had it. So far I've fed it aluminum, cast iron, hot rolled steel, and cold rolled steel, and it chewed them all just fine. The low speed capability is amazing, most of my non drilling work has been in the 550-800 RPM range, and it hold the set speed very well, rarely dropping more than ten RPM. I do feed it slow, but take pretty big bites.
I doubt you'll have any issues with it, just clean it and go!
Ruben
