- Apr 14, 2014
- 3,185
I can't say I'm a real fan of the Drill Doctor, even though I've had one for many years. They're OK for occasional use, but since they're 90+% plastic they will wear out considerably sooner than one built for commercial or industrial purposes. I must say I've slowed down in the last few years, but not that long ago I was sharpening 50 or more drills per month. At that rate the Drill Doctor didn't make it even 10 years before it was worn beyond use.
Post #25 in this thread includes a picture of the Black Diamond drill grinder I now use.
If you can find something on this order it'll last a lifetime. There are often several available on eBay, but don't get too hung up on the prices. They generally run in the $8,000.00 to $10,000.00 range new, but often sell for peanuts on the used market. I have seen several in the $300.00 to $500.00 range. Mine will sharpen fractional drills by 1/64" up to 3/4" . It will also sharpen letter drills A through Z, and number drills 1 through 60. If you go looking be sure the one you select includes a complete collet set. New collets from Black Diamond are about $55.00 each.
Which Drills to buy
I need to buy some drills (I understand you are not supposed to call them drill bits). I was looking at drill sets rather than individual drills. They have inch/metric. Also have drills lettered from A-Z and some listed as wire size. There are jobber drills and screw?? drills. Some sets are...
www.hobby-machinist.com
