- Dec 20, 2012
- 9,422
I remember when I was a new guy and everything was confusing. So many bits of conflicting advice. What I did was to assume/believe nothing and test everything until I figured out what worked best for me and have been doing it that way ever since. I'm sure you'll eventually settle on what works for you.
I have a Kinex level sensitive to 0.02mm/M. It is way too sensitive to use by itself, which is why I concurrently use a 98-6 sited right next to it. I use the latter to get close and the Kinex to finalize and it works really well. You have to be sure your levels are properly calibrated, which is why I included that doc for you to read. If your level(s) are off you will be chasing your tail so I would spend the time to get it right.
None of this is hard except for the first time you do it. Once you find what works for you, assessing your lathe will be simple and routine. Hang in there.
