- Nov 9, 2013
- 790
I have some differential oil that I use. All hypoid gear oils have extreme pressure additives but, E.P. additives are not necessary for straight cut gears. Some truck transmissions call for straight 30 weight engine oil because the gears are straight, not angled. I just drip a little on the gears while they rotate. Messy but, effective and cheap.
I use 90w-140 differential oil as well. Royal Purple specifically. I had a couple of extra quarts left over after I rebuilt my differential. It is sticky and clings to the gears pretty well. It drips out to a certain degree, but still leaves a good film of lubrication. I used it as assembly lube when I rebuilt my QCGB, and it helps the gears run smooth and quiet.
GG
