I may take a look at this stuff, Thanks.I use this on the open gears that need a little lubricant that will stay put.
http://www.goodspeedmotoring.com/wurth-hhs-k-high-pressure-lubricant.html
A can will last a couple years.
Dave
I use moly grease but my gears are protected by a cover. This grease is nice and thick and sticks like the proverbial to a wool blanket.
Paul.
Are they open or enclosed in a gear box?
I guess the question was , are they in a wet sump. Both of my lathes change gear boxes , for threading and feed, are in wet sumps, that I fill with hydraulic fluid.Xalky, the gears are enclosed in the gear box .
lithium grease and fine sawdust
