- Apr 21, 2015
- 653
That should work. Doesn't seem to reduce the part count though (you're just using your existing tee nut and have to make another piece to bolt to it).Then I'd take the "extended" piece of the design, and screw it's base to the t-nut.
Note that the original version of the design didn't have as much of a projection, and it wasn't stepped down. That meant the top of the tee base had to project above the top of the compound for the puck to swivel. With the step, this is no longer necessary, so you could use an existing tee nut.
The problem with using the pivot of the compound itself rather than an auxiliary pivot is that you have to get the center of rotation under the center of the ball for the final pass. Without an auxiliary pivot point, that requires a LOT of stick out (and subsequent chatter).
Cap screws work just as well as set screws to lock the tee nut, as does clamping from above. You just need clearance so the handle can swing ~180°.
Honestly, the set screws pushing up rather than clamping the ledge of the tee is more of a theoretical concern than a practical one. You'd really have to gorilla the screws to have any risk of damaging your compound.
