- Dec 26, 2015
- 2,079
When I need to thread slowly, I use an indexable “On Edge” threading tool (yours is the “Lay Down“ type), and HSS inserts from AR Warner. Here is a link to one version of that tool, and the HSS inserts that go with it.You CAN buy HSS insert tooling, which I hear good things about (@davidpbest can probably give you the best hints as our resident insert guy!), OR you can buy pre-ground HSS tooling that is pretty darn good, and probably just needs dressing every once in a while.
Kit #18 1/2 inch Threader NV
www.arwarnerco.com
